I see on some gut shots it goes to the switch, curiously its the positive side though, which I would expect to face the op amp instead of the switch if its the capacitor I think it is?
It also doesn't really correlate with the available schematics, I know the pedal pcb one is version 2.0, but the others are similar with nothing going to switch pin 1, but this looks like the capacitor goes to switch 1, with the resistors going to 2 and 3 as expected, but I notice the signal comes off of pin 3. Anyways, I would assume this is your 1u or 10u (depending on version) DC blocking capacitor, check continuity with the negative pole, closer to the pot and pin 7 on the IC.
