icedcreameyes
Hi there,
I have just built the muffin fuzz board, I built it as a Martian Fuzz, and to be honest it just sounds a bit crap... So I think there is a problem.
The main issue I'm getting is that when I hit a chord quite hard on the guitar the pedal responds by going super thin, super compressed and choked. Kind of sound like I've hit a trash can with a stick.
So far I have a couple of ideas
1. It seems like the Martian Fuzz is slightly higher gain than the standard muff? The resistors that are attached the emitters in the clipping stages run straight to ground which I think will increase gain? Perhaps I need to lower the gain?
2. My transistors aren't making solid connection due to the sockets I've installed?
3. I built this one with fairly average parts so perhaps they aren't good enough. (I don't think it's this because the sound of the pedal is quite off, more so than just tonally bad I.e. more broken than just Behringer).
I've checked over my solder points and parts values etc and I'm confident this is not the issue.
Any help would be greatly appreciated. Here is a gut shot...
