Muzzle Classic
dmnCrawler
Pandemic Pedal #31
I had to fix a bunch of problems I had when building this pedal.
  • My elecrolytics were too big so I had to leave the leads long on one and lean it to the side.
  • The 560nF cap on the left is under the board because the one I had was too wide to fit.
  • The red/blue LED I had was center anode and I did not like the way the red/green looked. So I used an RGB LED and just bent the green lead out of the way.
  • I did not realize that the isolated jacks I used for the side chain would add so much noise. I had to add a ground wire from the two of them to ground to get rid of the noise.
The pedal now works and sounds great. I can not wait to get more play time through this thing.
