Danbieranowski
Built a properly working Muzzle (from an audio standpoint), but the LED doesn't light up. I had to sub the 5k6 resistors for 5k1 bc it was the nearest value I had on hand. Is this too low and it's just killing the LED? I've never used bi-color before so I'm not sure if they behave differently.
I'm using these common cathode LEDs from Small Bear: https://smallbear-electronics.mybigcommerce.com/led-5mm-bi-color-diffused-water-clear/
So the LEDs shouldn't be a problem.
Not uploading pictures and such yet, as the whole pedal works other than just the LED (I've tried two now so I don't think it's a bad LED).
Is it possible to use this pedal with a single LED without the "gating" being shown (just as a test)?
Anyways, I'm just full of questions today! Party on ya'll.
Link to Muzzle build doc: https://docs.pedalpcb.com/project/PedalPCB-Muzzle-Classic.pdf
