Hi, all. I have mentioned this to a couple of people (privately) so far, but there hasn't been much interest. I'll describe what I'm doing here in case anybody is interested in hearing about it, or maybe even messing around with it. I am designing a multi effects loop switcher that can be set up in either 4 or 8 "rail" configurations because the boards are designed to be modular. You can use one set of boards for 4 rails, or 2 sets of boards for 8 rails. That's the quick and dirty version. Ok, maybe not so dirty? I don't know if you're all over 18 or not!!! If this is completely uninteresting to you, then now is the time to bail out of here and move on to cooler and more interesting threads, because the deep dive follows.
Most of you are aware of Jack Orman's circuits, right? I am pretty new to pedal building, and in my searches, I ran into his site and found two circuits that really interested me: a JFET splitter, reported to be quite transparent as far as active splitters go, and an op-amp mixer circuit that also has a ton of positive commentary on it, too. I have been interested in an effects loop box so that I can isolate some of my bass effects pedals, and switch pedals or short chains of pedals on and off as needed, but I didn't see any with all of the features that I wanted. I grabbed these two circuits and taught myself how to use KiCad. I designed boards for both circuits that can be used alone, or they can be tied to a second board of its type. I.e., you can use one splitter and one mixer, or you can connect two splitter boards (and two mixer boards) together by using a wire between the Molex headers on the boards.
So far, this is just like any effects loop switcher box. What is missing from pretty much all of the ones that I found was an XLR board-level output. This was really easy to add, because Jensen has some schematics online. I designed a board with a circuit that incorporates a Jenson step-down transformer for XLR out that will be parallel to the original signal output (1/4 phono).
The board(s) can be run on a wide variety of voltages for more headroom, if desired. Since I am not an EE, I am not really sure what would be close to "ideal" for the 4-rail configuration, and what would be ideal for the 8-rail configuration. Either way, there is a trim pot for the power that goes to all of the switch LEDs to adjust the brightness for whatever voltage you use, and whatever brightness is good for you.
I would like to add USB output, just for fun. I bought a Teensy 4.0 with their audio shield to play around with, once I get boards fabricated and do my first build of this. I am probably going to use OSH Park (recommendation from a friend), and I'll get boards made sometime soon. This is all just for fun and learning for me, and I would be happy to share what I have, so far, with anyone who might want to have a look and play around. And even inform me of mistakes and bad assumptions that I made. Just let me know, and I'll give you the KiCad 6 projects that I have for the 3 boards. If you actually made it this far, thank you for reading.
