new benson temperature stabilized germanium fuzz
zgrav
Hmmm. Would you think the germanium transistor for the new Benson pedal is warmed to the desired operating range when it is powered? Seems like the LED also changes color as it gets hotter. I have wondered whether it might be simpler to put a small peltier close enough to keep the transistor cooler since that is closer to the way that the circuits are originally running.
It seems like the long way around. Why design an inherently instable circuit only to "stabilize" it with a gimmick? There are plenty of germanium circuits that aren't fussy about temp. And IF you were to use this in such extreme temps, won't you have to plug it in and wait for it to "stabilize" before you can use it?
if Benson heats up the GE transistor(s), it seems like an opportunity for someone else to use a peltier cooler to keep a GE fuzz chilled. Seems like it would not take a lot of juice to cool such a small area. No need to chill the whole pedal, and you could even call it the "Mussy Pelter"
