malsanders
Hey guys, I have just bought a stack of PedalPCB's including the Sunflower.
I have done some research and 'think' I know the answer, but is using 1/4 watt resistors OK in the sunflower?
The original Fuzz Face used 1/2 watt carbon comp (same values as the Sunflower), and the AM Surface uses carbon comp but I'm not sure on the wattage.
I would like to stick to the original if I can and use carbon comp, but will they:
1. Fit in the 8mm spacing (carbon comp's on Mouser are 9.5mm) ?
2: Work in this circuit?
Thanks!
Thanks!
