Big Monk
Long story short: My TC Electronic Drip Spring Reverb has an incredibly rich spring reverb tone but falls short, noticeably, from unity gain.
TC Electronic won't give me the schematic and punted me to their service vendors. Service Vendors are of course not going to give it to me either. Anyway, it's all SMD anyway so it would be a paint to modify, even if it was only changing the divider ratio that I am sure exists on the tail end.
So, I was thinking that I could use a simply JFET buffer with gain control after the reverb, built into a little tap tempo box, like the one used on Tonepad's Buffered Wah schematic:
If I am correct, the 2N5457 should only have about 6 dB on tap and could be easily set with a volume control to match unity if put after the reverb.
Any thoughts or suggestions?
As a side note, my Carl Martin Surf Trem has the opposite issue, as it boosts the signal a touch over unity when engaged. That has normal through hole components, however, and East Sound Research sent me the schematic with no issues. Just need to tweak the voltage divider on that one.
