Built this a while ago and until recently it was working perfectly. The other day I noticed that the setting I usually use on my Paragon Mini was much lower and I wasn’t getting unity gain until about 2 o’clock on the level knob where before it was around noon if not a bit lower.
voltage readings on ICs:
IC1
1 4.89v
2 4.89v
3 2.42
4 0v
5 4.70v
6 4.89v
7 4.75v
8 9.55v
IC2
1 4.97v
2 4.97v
3 2.50v
4 0v
5 1.96v
6 7.34v
7 1.32v
8 9.55v
I was under the impression that all pins but 4 (0v) and 8 (about 9v) should be reading around 4.5v So it seems like something is definitely amiss
SW3 is set so 1 is ON and 2 is OFF
SW4 is set so 1 is OFF and 2 is ON
Appreciate any insight
IC1
1 4.89v
2 4.89v
3 2.42
4 0v
5 4.70v
6 4.89v
7 4.75v
8 9.55v
IC2
1 4.97v
2 4.97v
3 2.50v
4 0v
5 1.96v
6 7.34v
7 1.32v
8 9.55v
