This is the third Paragon Mini I've built and like the other two this one is going to a friend. One of these days I'll build one for myself. I think I like this better than the regular Paragon. Eventually I'll build the regular Paragon with the mods going around so I can compare. Of the three I've built I like this one best. The first one I built I used 100k for R3 (High Gain), 1k for R20 and 1N914 diodes. The second one I used 10k for R3 and R20 (values printed on the board and supposedly the original KoT values) and BAS33 diodes. On this one I used 100k for R3 (High Gain), 1k for R20 and BAS33 diodes.
On the KoT I use each side like Analogman sets up the pedals by default. OD on the right side and Boost on the left. With that configuration I like the high gain option on the right using the 100k mod. The pedal sounds decent with 1N914s but for me it misses that little something that you might not notice if you haven't played one with the MA856s. I really like the BAS33s to get that little extra KoT vibe. It's a really minor difference but for my tastes that's my preference. BA282s were good to but the BAS33s are easier to source and feel good to my ears. Even with 1N914 diodes this is a great build if you like the bluesbreaker circuit.
I don't really use the hard clipping option but for the first build I used 1N4001 diodes and for the other two I used 1N914. I believe you want to aim for something with a lower forward voltage in these spots.
