Hello all,
Thank you in advance for taking the time to have a look at my problem.
Bypass works, no sound when either footswitch is engaged, LEDs do light up. I checked for any shorts, reflowed all (I think) connections, checked for continuity between footswitch board and main board (all good), and checked to make sure the footswitches had continuity in active and bypass modes (all good). It appears that it may be something to do with the power coming in?
Power in voltages:
D7: 9.8v
Pins 1& 8 on IC3 (no IC inserted): 3.7v
D14: 3.7v
D15: 1.8v
C21: anode 1.8v, cathode 1.2v
C22: anode 1.2v, cathode 1.v
C11: 0v
With all of the IC's in place, I get 9.8v at the anode of D7, and 0v at the cathode and pins 1/8 on IC3.
Thanks again for taking the time!
Power in voltages:
D7: 9.8v
D14: 3.7v
D15: 1.8v
C11: 0v
