desmondtencents
Built this one a couple of weeks ago as a custom request. The basic idea for the graphics were from the customer, I put this together and got his seal of approval.
I had already laid out the control labels before even considering the clipping diode arrangement so I just moved a few things around to match the labeling. Ended up going with Germanium along with Silicon or LED instead of symmetric/asymmetric. Also used BAT46 diodes in the octave section instead of Germanium as I figured the bias voltage was more important than any "mojo" from using Germanium here. It's also important to make sure those diodes are as closely matched as possible for the best octave effect and Germanium bits sway a lot with temperature variation.
The enclosure was UV printed on an ivory enclosure from Tayda.
