Hi all, I recently finished the new ABY switch and I’m having issues with the ground lift. So I have relocated the ground switch to a spst toggle on the surface so it would be accessible without opening the enclosure. My issue, when I engage the ground lift a terrible 60 cycle hum comes thru the B side and no signal behind it. The only thing I don’t have on the build is the keystone 628 ground spring. I do have a cliff-jack ground ring on the input of the switcher since I had a few on hand. I have attached photos below, Any suggestions would be appreciated! Thanks!!
