I've seen some dead links to those, but gave up after 4-5. If I may, are you designing a pedal or amp board?
I can think of at least a half-dozen members who might have those. I look forward to seeing your ideas.
Let me know if that works.
His life now complete, Mr. Monk turns his attention inward, delving deep into the inner most recesses of his mind. Follow him on this most fascinating journey.@Big Monk said: Worked like a charm and has everything I need!
Well not exactly....I enjoy your projects. They are unique to my own in that they have both a start AND end to them.If by Journey you mean stream of consciousness rambling about stuff no one cares about, i.e. using the forum as my personal build journal, you got it!
Here's what I am working on:
It's a variation of Mark Huss' version of a Single Ended Plexi with a few tweaks. I'm using the Valve Junior power supply and power amp stage (EL84), a 3PDT to switch between Bright/Normal voicing, a Drive control on the input of the EL84 and variable NFB.
His version is particularly cool because of the Faux PI stage where he injects the NFB and has a Presence control.
Going to be designing a board for this.
Other than that I dig it.
- I think you swapped your Drive and Volume pot labels
- What's the reasoning behind your master volume setup? Lug 1 floating, 470R resistor pulling to ground before a series 10k?
So you made a master volume control with a fixed maximum level. It's not affecting the gain of any of your preamp stages, it just controls the possibility of power stage clipping by choking the level of your preamp output.The Drive control forms a voltage divider with the grid leak 220k
