Has anyone tried this and got good results?
Very few clones of mutron out there. Would’ve loved if PP carried it.
Thanks for reply. Any particular reason you prefer kraken over vutron?Given the choice, I'd probably prefer the madbean kraken
Thanks will check them out. This is for bass guitar btw. Not sure if it matters.I know they're two different beasts altogether, but I'd really recommend something based on the Mu-Tron III envelope filter, like the Fuzz Dog MOO-Tron, rather than the Vutron which is based on the Mu-Tron V envelope filter. If you're looking for a V-styled filter, I'm sure any of the available PCBs are great, but if you're looking for the classic Mu-Tron sound, as well as what I consider to be a much better filter in every way, you'll really want a III-styled filter.
Good to know!I have built one and it’s meh/alright. Low part count so pretty easy. The Madbean MiniMu blows it out of the water.
Madbean does a better job with layouts and documentation. pcbguitarwhatshisfuck lifts Madbean's designs, poorly. Just go to the source and talent and support a better human being.Thanks for reply. Any particular reason you prefer kraken over vutron?
I can check later and get some voltages for you. Can you please post some pictures of your board, Component and solder side along with the off board wiring (jacks/power/switch)Good to know!
Any chance you’ve a voltage map with 13700 IC? I pretty much traced the entire circuit for smoking Gun and I’m ready to give up.
Bypass works fine. When effect is turned on, I only get cleanish with less treble. No filter effect at all. I’ve checked wiring, component values, solder shorts and replaced ICs. I do get supplies correctly at IC pins vc 9v and vb 4.9ish. And have traced the Transistor voltages and pinouts. Using exact components per BOM, except 5088 instead of 5089. Rest are all per BOM.
Gotta check out other options from you guys .
That damn cosmos delay is the only pedal (from any pcb supplier) thus far I have not been able to troubleshoot or get working properly.Madbean does a better job with layouts and documentation. pcbguitarwhatshisfuck lifts Madbean's designs, poorly. Just go to the source and talent and support a better human being.
Has anyone ever successfully built one? I've never seen itThat damn cosmos delay is the only pedal (from any pcb supplier) thus far I have not been able to troubleshoot or get working properly.
Will do in a bit. I did have to go through lot of pain to replace stuff due to troubleshooting. It is definitely not a pretty sight. Interestingly, whatever I’ve done to it hasn’t changed the behavior at all since the beginning, which means I’m not looking at the right place or something weird with pcb. I did find one of pots needs 2-3 to be shorted per schematic but are not shorted on pcb.I can check later and get some voltages for you. Can you please post some pictures of your board, Component and solder side along with the off board wiring (jacks/power/switch)
Same with the vu-tron. I haven’t seen any activity online. Although they’ve a “5k+ strong private group” on Facebook. I could go join Facebook just to get an idea about troubleshooting from that “private group”. But I prefer here and worst case I’ll Chuck the pcb and go other options.Has anyone ever successfully built one? I've never seen it
Only thing I have seen is troubleshooting requests on aforementioned Facebook group. Only reason I joined the group was for that build. For what it’s worth, I did build the vu-tron and their master phaser (maestro phaser) which both work, but have not bought anything from them since, nor will IHas anyone ever successfully built one? I've never seen it
It looks bad but I’ve made sure no blobs and accidental shorts are there. Again, not my usual work style but never had so much bad luck with any ppcb boards so far.I can check later and get some voltages for you. Can you please post some pictures of your board, Component and solder side along with the off board wiring (jacks/power/switch)
I wondered ab that, but I was thinking the 5089 was a PNP, but upon google search I retracted my thought. Guess I need to look at some datasheets to figure out the differences between 5088 and 89The 5088 and 5089 aren't interchangeable.
I did try nte47 prior to that as well- which is claimed to be a direct equivalent of 5089. Those are only ones I could source in USA. I do rightly have 5087 for the pnp.The 5088 and 5089 aren't interchangeable.
I’ll dig in too. 5089 is npn and 5087 is pnp. I’ve in the past successfully used 5088 in place of 5089. But this could very well be circuit dependent. Not sure.I wondered ab that, but I was thinking the 5089 was a PNP, but upon google search I retracted my thought. Guess I need to look at some datasheets to figure out the differences between 5088 and 89
