In essence, this is what a trimmer is. When biasing using one, you are adjusting the resistance in or out of a transistor (or possibly another component or stage I suppose).
Once they are set you can measure as mentioned above, and replace the trimmer with a resistor of the same value.
Edit: Although I should note that anything I say in relation to electronics is subject to scrutiny.
