Thanks for the heads up. Tight fits are always the tricky ones. Starting mine soon.Here is the build of my Pro-10. It is a very tight fit. I found that you can not use dust caps on the pots underneath the input and output jacks. Also, neutrik jacks did not work. The only style of jacks that fit were the ones I have in the build.
View attachment 27242View attachment 27243
Sounds likely, I didn't have any noise on mine.Just an update. I swapped the op amps from the Pro-10 Blue into the Dual one and the issue went away. I think I got a bad batch of opamps.
Tayda? Or other source?Just an update. I swapped the op amps from the Pro-10 Blue into the Dual one and the issue went away. I think I got a bad batch of opamps.
The whole fact Tayda exists amazes me. Don’t even consider that you can get a box from the other side of the planet in less than a week for $15. So crazy. Kudos Tayda.The TL0701s and TLO702s I got from Tayda were good and didn't have any noise. I forget the supplier I got the other ones from, but those ones were bad. I went through all of the ones from the other supplier and they all had that noise problem. @spi
