So I finally got my adapter ring for the 1590BB all fitted correctly and it looks great! Fit like a glove on the lip around the lid of the enclosure. Screws are a little tight but the material is soft enough to be screwed through with a screwdriver and a gentle pressure. I’m really pumped this thing works so well with these enclosures.
on to the pedal itself… Wow. The blue side is just excellent. This will never leave my board for that side alone. To be honest the modified ODR 1 on the green side almost has too much gain taken away for standalone use (esp when the blue side is so good) but where this thing really sells it’s dual drive form is when they are both on. I can have a slightly driven sound with the blue side that really breaks up nice with guitar volume and attack and cleans up too. When you put the green on at the same time it’s just a monster. I’ll get a video at some point.
Green side also sounds better with a boost in front too.
side note: this would fit without the adapter if I used slightlyyyy shorter electro caps.
