Fizz
- Build Rating
- 5.00 star(s)
I built this one yesterday and it was an easy and fun build. Soldering all those pins was a great soldering exercise. So were the big lugs and holes that I don't usually see on PCB builds. I can't wait to start testing pedals on this.
I used the from AP1084D33G AP1084 LDO Voltage Regulator IC 3.3V 5A from Tayda and it was slightly too large but somehow I got it to work by adding a little more solder. I used the from LM1117 LM1117MPX 5.0V 800mA Low-Dropout Linear Voltage Regulator from Tayda and it was a perfect fit.
All my voltages on the pins tested perfect except the 18v was around 17.85 which is close enough.
I love that it has an on/off switch so I can test builds in line with others.
What is the Effects Bypass used for?
What is the best method to test PCB builds before I box them up.. how should I connect the breadboard wires to the PCB without soldering them?
