hateboardlove
Hi all! This is my second build, and I'm getting a pretty significant volume drop problem I believe. Although it is also a bit more noisy than I think is normal. The only thing I can think of myself is that the transistors I'm using must be too weak? Trying to bias I have the multimeter black connecter to the ground on the auditorium test platform and the red on the collector and only read a max of a little over -1, as I understand this should be somewhere around -4.5? It's extremely loud as well, sounding as if it may not be grounded somewhere?
Another thing that is slightly confusing to me is the trim pots on almost all pcbs have 5 pins while the trimmers I've seen to order all only have 3 pins, while soldering this circuit I just added some solder to those extra two holes but I don't really understand what is going on there and would love to know about that if someone could explain this? I've looked around myself but haven't been able to find this out myself.
Major mistakes during the build I made were soldering the rotary switch and potentiometer on the wrong side so had to cut the rotary switch apart to get it off and scratched the pcb a bit and it is showing a bit of the copper circuit I think. The connections for the those two switches are now the right side but they are not super tight to the pcb. Could any of this be the problem?
Those 2 things are the only big errors in making this but aside from the transistor maybe being weak I'm not sure where a volume drop may be occurring, though it could be my beginners soldering skills too but would love some help on this! Thank you in advance to anybody who has the time!\ Also any tips opinions regarding my soldering or anything else they see I would love to hear it!
soundcloud audio clips for full volume, half volume and on off test between the pedal and bypassed with an ac30 patch on my hxstomp:
