It's doesnt sound when is off and when It's on the noise is very loud
Travis Active member Nov 14, 2019 #1 It's doesnt sound when is off and when It's on the noise is very loud
Travis Active member Nov 14, 2019 #2 Photo Attachments PhotoPictureResizer_191114_202228732-2016x1512.jpg 697.2 KB · Views: 30
Chuck D. Bones Circuit Wizard Nov 14, 2019 #5 Please move this to Troubleshooting. And do some visual inspection of both sides of the board. If there is a bad solder joint or conductive debris, you will find it. Way too much solder on the Si diodes. Make sure the JFET is tight in the socket.
Cybercow Well-known member Nov 14, 2019 #6 Reflow and maybe add a tiny touch of solder to the pots, some of those resistors and wiring to the daughterboard.
