Sandspur no clean signal
Billyhank
I finished my Sandspur and it sounds fantastic.
The issue I have is absolutely no clean signal.
When I turn the pedal on I get sweet, sweet fuzz. But when it’s off I get no signal at all. I know my wiring is spaghetti. But, I made sure I attached the correct wire to the correct spots on the footswitch. (I think, lol)
BB0756AE-00AC-4629-8CE0-AC1FEF1334C0.jpeg F1FB0F1C-8407-4028-8A5A-B87377AB721E.jpeg
Just hold your soldering iron tip on each joint for around 4 seconds until the solder flows making sure you get a good connection on the wire ends and 3PDT lugs hopefully it's just a dry joint
If not check continuity in bypass between the middle common row lugs and the bottom row lugs of your 3PDT
