Chuck D. Bones
Circuit Wizard
As requested, here are the mods I performed on my Sea Horse to increase the delay, increase the SHAPE range, improve the filtering, change the LFO speed range and one or two other things. It does everything that the Sea Horse and Dark Rift do, but with better filtering. These mods assume you are building on the revised Sea Horse board, dated 01-06-20. That board has the LFO tick fix built-in. You can perform all mods or any combination; one does not depend on the others. Here's a hi-res photo of my modded board for guidance on parts placement. Note: this was the previous rev board, so one or two parts may have moved.
Delay Mod
This mod extends the max delay time out to about 660ms (DEPTH set at zero). Optional.
Change ANIM pot from B2K to B50K. It's now called TIME. NOTE: Maxing both TIME & DEPTH can cause glitching in the delay chip, it's normal. Back off a little on one or both and the glitching goes away.
Delete R11.
Add a 33K resistor from ANIM-1 to DEPTH-2.
Change R7 from 2.2K to 1.5K.
Filter Mod
This mod re-tunes the input anti-alias filter (LPF1) and routes the delayed signal thru the output filter (LPF2). Recommended.
Change C7 from 1uF to 10uF.
Change C17 from 100pF to 220pF.
Add a 6.8nF cap from the right-hand side of R3 to the right-hand side of R33 (verify that the right-hand side of R33 is ground, I don't have the latest board).
Change R4 from 33K to 22K.
Delete R13 and C15.
Connect a wire from C15- pad to DIM-3.
Change R14-R18 from 10K to 47K (I used 51K, but either will work, just make them all the same).
Feedback Mod
This mod limits the signal amplitude when FEEDBACK (DIM) is maxed and the delay goes into self-oscillation. These diodes are built-in on the Dark Rift. Recommended.
Add 1N4148 diodes back-to-back from DIM-1 to DIM-2.
LFO Rate Mod
This mod changes the LFO speed range to 0.1Hz - 10Hz and improves the RATE control sweep. The slower rates are desirable when using longer delay settings.
Change R25 from 10K to 22K.
Delete R22 & R23.
Change R26 & R27 from 10K to 33K.
Change R34 & R35 from 100K to 10K.
Change C20 to 1uF film.
LFO SHAPE Mod
This mod extends the SHAPE range further into the square wave territory, allowing more abrupt sweeps and stronger pitch shifting when SHAPE is maxed.
Totally optional.
Change SHAPE pot from A100K to A250K.
Delay Mod
Delete R11.
Filter Mod
Delete R13 and C15.
Feedback Mod
LFO Rate Mod
Delete R22 & R23.
LFO SHAPE Mod
Totally optional.
