caspercody
Looks like my old topic on this was deleted from the server transfer.
I got my Seabed delay working, but I have a bad PCB. I had to lift the one side of R16 (closest side to PT2399) and solder a jumper wire from the lifted side and connect to PIN 12 of PT2399.
Why, using a DMM, R16 was connected to PIN 11 and not PIN 12. All I was getting was a clean signal out, with none of the POT's making any difference in the sound.
After a lot of work, I used a audio probe and noticed sound out of PIN 12, but nothing on either side of R16.
But my deelay sound out is not exactly clean, there sounds like a little crackle to the tone. Should this be a clean tone coming out?
With all POT's turned off, clean tone. Once I start to turn up level and delay, I get a crackle at end of note. Mostly when I strum harder.
When I use a audio probe, at PIN 8 it is a fuzzy tone coming out. Is that normal?
Thanks
Rob
Thanks
Rob
