Seahorse "The Depths"
Nice as usual!
I was confused by "The Depths" moniker because I just built one (EQD Depths\PedalPCB Abyss) and it had 5 knobs, not 6...
Were you trying to make me loose my sanity? ;)
Looking good! This is the next one in my queue. Good to know that yours doesn't tick.
Did you happen to notice that the names of the DEPTH and INTENSITY controls are swapped on the board w.r.t. the EQD Sea Machine manual? The pot values are correct, just the names are swapped. Not a big deal.
There is a lot of similarity between this pedal and the Dark Rift. Main difference is the Dark Rift has longer delay available.
I should have been more specific. Not the location, the function is swapped. On the schematic and board, the blend control is named "DEPTH."
By "pronounced effect" do you mean that the modulation is the strongest?
For further troubleshooting help, please post in the Troubleshooting forum.
From what i hear Depth pot is basically Mix/Blend control, with 50% in the middle.
Did that make any sens according to schematic in your opinion?
Try reading post #9 above, it describes what each control does. Those words were copied from EQD's Sea Machine user manual.
