spi Well-known member Mar 30, 2021 #1 How does this daughterboard get secured inside the pedal? It doesn't look like the switch gets soldered directly to the board in the way a 3pdt does.
B benny_profane Well-known member Mar 30, 2021 #2 spi said: How does this daughterboard get secured inside the pedal? It doesn't look like the switch gets soldered directly to the board in the way a 3pdt does. Click to expand... I usually just put some double-sided tape between the SPST switch and the board.
Robert Reverse Engineer Mar 30, 2021 #3 If you use it with a PedalPCB (or similar) PCB you can attach it directly to the IN/GND/SW/OUT with a pin header.
