Having issues with these boards!
I purchased a bunch of these from Buggs for making an 8 channel strip true bypass looper utilizing clickless momentary trigger.
I'm getting a a "click" "click" when it is engaged or disengaged! I'm using the Latching version and hooking it up like Buggs said without the one transistor and LED hooked up to where the transistor would be.
I'm not hooking these up to one of PedalPCB pedals, but some commercial pedals.
At first I wasn't getting signal, then I figure out the IN and OUT. I figured the out of the pedal would go into the IN, but no, it's as labeled and Out of the pedal needed to go to the OUT of the circuit. I thought maybe grounding issue and messed with that, but still having issues. It isn't quiet either. Not sure what is up, but contacted Buggs twice and supplied detailed question along with video and did not get a response!!
I need this solved. Been working on this for months!! Any help would be greatly appreciated.
ref: bypass unit - https://www.pedalpcb.com/product/pcb394/
ref: chirp - https://drive.google.com/file/d/1_5WZkwMOaLkKlSksKnjR6n2gM8NfrAyV/view?usp=sharing
ref: noise - https://drive.google.com/file/d/1Glzb0FZ6kHxTSxtpiBw32yMHYiM8ONH6/view?usp=sharing
ref: grounding and hook up: https://drive.google.com/file/d/1s5WxQP6LoXhJD7vDppYt9QPzVc8M7STb/view?usp=sharing
