ok.
well, the data sheet of the lt1054 states:
Operating Range, 3.5 V to 15 V.
so i guess, feeding 15v into it would create 30v on the output? probably some electr. capacitors would get damaged in that case.... but how about 12v input? 24v output voltage should work for all components i guess?
i just asked, since i noticed that hutson states on their site:
The Broadcast requires a DC power supply unit (PSU) and can run at voltages between 9v and 24v; running the Broadcast at voltages higher than 9v gives it more headroom, output level and clarity. This is great for use with bass or when using the Broadcast as a clean pre-amp boost.
