Rpschultz13
I'm developing a tuner pedal, and trying to give the option of True Bypass or Buffered Bypass. The JFET splitter/buffer I'm copying from AMZ (PPCB uses similar). I've always understood that TB means the signal doesn't go through any IC's, chips, or anything that is powered. But can go through switches/resistance, etc.
In the below example for TB mode, the signal goes through SW1 and the relay but nothing powered. But the signal ALSO goes through Q1 to the tuner. I think the buffer creates a sufficiently high impedance such that it doesn't affect the parallel signal going through the TB leg, but I'm not sure.
Thoughts?
Thanks!
Thoughts?
Thanks!
