I typically never solder ICs (and rarely solder transistors), so I'm a little skittish/overly-cautious with my first FV-1.
Pretty much the only question I have is: how long should I wait in between soldering each leg?
EDIT: I've already started soldering this one, but it's slow going as I'm waiting between soldering each joint.
Years ago, I read that when soldering photocells, you should solder one leg, then wait 5min or so, then the next, repeat.
I'm just taking the same precaution with the FV-1 until I hear otherwise.
