Problem: A solder pad on the Son of Ben PCB came off while installing components. The PCB requires a conducting bridge between the two solder pads when using a single gang potentiometer in the bass pot position.
Solution: Bridge the two component holes as shown in the picture below by soldering a piece component lead or wire into the holes. Credit to @music6000 and @giovanni
Original Post:
I am working on a Son of Ben. I have most of it soldered but was waiting on a B2M pot (I wasn't able to find a dual gang B1M). I had a very hard time trying to solder the bridge as required for using the B2M and when I finally got it some on and tried to trim it a little one of the solder pads of the bridge came off along with all the solder. Is there a way to fix this or have I ruined the PCB?
Original Post:
