Mouser sells Rubycon electros that are 5mm high IIRC. Plenty of 7mm ones too in normal times, but my usual go-tos have been out of stock for at least a year.Working on getting parts together for Round Two of ElectroVibe Mini/Monk Vibe Prototyping and I’m struggling to get 10u, 47u and 100u low profile caps.
1u in tantalum and 2.2u in tantalum I can get from Tayda and they are short enough.
Any good sources?
Did you even check mouser?
Smallbear has them.
The Rubycons showed as being in stock a few minutes ago.I did! The filtering didn’t seem to return any 5mm/7mm height caps in stock that I needed.
Maybe I need to check again.
I think this is the issue I’m running into.
The 10uf are actually 50v if you look at the options, but yeah, unfortunately the others are only 16.
What values are you looking for? I can give you part numbers off my labels
1u
140-SEA1R0M1HBK0407
140-SS01M1H0305P
10u
140-SS100M1E0505P
47u
140-SS470M1E0605P
100u
140-SS101M1E0805P
I'm not saying these are in stock, just that's what I've ordered there in the past
It’s not uncommon for dimensions to get swapped around or omitted in the Mouser and Digitech search engines, IME. It sometimes helps when you already have the part numbers, for sure.Shame, shame!
Ask @Harry Klippton and he’ll tell you I’m a seasoned component hunter. I must have selected the incorrect parameter for height.
