andrewsrea Well-known member Nov 9, 2024 #1 I've seemed to run dry on sources for M7 internal-tooth lock washers, for use with 16mm potentiometers, commonly used on pedals. Any suggestions?
andrewsrea Well-known member Nov 9, 2024 #3 jwin615 said: Try 1/4 or 9/32? Click to expand... 1/4" are too small. 5/16th would work. Do you have a preferred source?
Passinwind Well-known member Nov 9, 2024 #4 Lock Washer - Serrated With "Teeth" - Bag of 10 Give your pots and mini toggle switches grip by using a serrated lock washer. The “teeth” on this washer add friction so hardware stays put. For M7 bushing. lovemyswitches.com
darwin999 Well-known member Nov 10, 2024 #5 andrewsrea said: I've seemed to run dry on sources for M7 internal-tooth lock washers, for use with 16mm potentiometers, commonly used on pedals. Any suggestions? Click to expand... Try McMaster-Carr: McMaster-Carr McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day. www.mcmaster.com
darwin999 Well-known member Nov 11, 2024 #6 McMaster-Carr is my go-to source when it comes to various nuts, screws, bolts, threaded inserts, and such. They are a high-quality supplier.
