Spirit Box Question
Revisionist
So I have built (mostly) my spirit box and am waiting for the accutronics reverb module to arrive today. I've checked the forum and cannot find pictures (and the document does not say) how I attach it. I'm guessing it goes on the back side of the PCB, but since it was expensive to purchase (and I had to wait a week to get it), I want to make sure I don't screw it up.
Thanks!
Take a look at this. If you still have questions, try starting a conversation with griff.
Thank you. I had looked at it, but I'm being extra careful/paranoid and was hoping to see a photo showing the other side of the pcb. Honestly, there is really only one way to attach it to the board, but considering the kind of really stupid mistakes I've made in the past, I try not to assume.
For extra peace of mind, always try to figure out the why behind off board wiring / installing components.
for example you can see on the pcb, the 3rd hole from the left is connected to the ground plane.
on the BTDR-2 datasheet, pin 4 is ground. You can see that installing it the way shown in that build doc, pin 4 will indeed line up with the hole that is connected to the ground plane.
