Suhr Koko Boost
equinox
I'm opening up a thread on the Suhr Koko Boost as it's been YEARS and a LOT of A-listers use it in their rig, but still, no one is/has been cloning it!!
They have 2 versions...the one in the double-size enclosure and the newer one in the single package.
I had the dual one and worked to reverse it (Koko Boost Rev 3A), but at the time, I was having issues with my soldering iron and temperature sensor and it fried a couple of the components, so was unable to do an 100% accurate trace/reversal!
I can post what I had and left off and hopefully get some traction in getting this thing reversed and a clone unit/PCB created.
There was also some preliminary schematic(s) created by someone else. I hope this helps.
This is the second time today I saw a circuit that had this arrangement of transistor and diode between stages. What does this do, and what is it called? I tried to google it but I'm not finding anything.
It's a JFET switch. Pulling the cathode end of the diode low turns the JFET off.
Take a look at pretty much any Boss or older Maxon/Ibanez schematic and you'll see a similar arrangement for bypass switching.
Does this have the "Hold footswitch for alternate function" trick like some of the other Suhr pedals?
Reactions: spi
More photos
I don't think so about any kind of "Holds". In the pics, you can see the footswitches used and in the BOM I had identified and entered as momentary (normally open)
Ahh yep, the "Reloaded" version does the Hold trick.
The standard model has switchable buffered/true-bypass, that's likely where the JFET switches come into play.
Looks great! Did you happen to trace the power supply?
I did not personally.
Someone else did the preamp schematic. I provided all of the photos and depopulated PCB(s) and can again along with Bill Of Materials if anyone is interested to complete this. I have no time to delve into it currently.
