Sunflower Cleanup Help
Travis
Hi, I´m start learning about fuzz pedals, I love the sound of some original fuzz faces I try, especially when I turn volume down.
I build the sunflower build and I´m trying with some transistors and different hfe values but I can´t get a good sparkle cleanup fuzz tone.
Some recommendation? Thanks :)
Big Monk
Have you tried the clean trimpot?
JamieJ
Part numbers don’t equal great fuzz tones. It’s all about how they are biased via the 33k or 8k2 resistors in the original.
Check this article out and test the bias points to see how well your transitiors are biased with your current build
thewintersoldier
For Q1 use something with an hfe of 60-90 and for Q2 an hfe of 100-130. The leakage on both should be ass low as possible. When you bias it set the external bias to 12 o clock and then set the internal bias for 4.5 v. You should get good cleanup with single coils. Humbuckers you will need to tweak the circuit some. The Joe bonamassa ff was made for humbuckers. The ff circuit also sounds best into a pushed or slightly driven amp.
thewintersoldier
There's no magic in parts. It's all tuning.
Post your collector voltages and the capacitor values you used.
Unless your after a certain sound like Eric Johnson you shouldn't need to tune it. They never did back in the day and as long as your transistors are withing the usable range you should be just fine with adjusting the Q2 collector trimmer.
Big Monk
I agree with you 100% if you have a big pool of transistors to pick from because you can swap until it sounds right.
If you just buy a few for a project you’ll likely have to tune the circuit to accommodate.
thesmokingman
Paid Hater
things of note:
sunflower does use a charge pump and those aren't the same as battery power which isn't the same as carbon battery power (sunbeam brand from the dollar store are magic) wrt to playing the fuzz face in a more dynamic manner ... I took the Pepsi challenge on this one and it is one of the few mojo/unobtanium items that holds up
ge fuzz faces with medium or low gain transistors can be a little dark but are generally more dynamic than higher gain
I had more but this post has been interrupted many, many times by work ...
zgrav
things of note:
OK --- maybe not a MAGIC battery -- but more or less the same point.
Coda
Don't forget that Hendrix was using a magic 9-volt battery.....
Nah…you’re thinking of Bob Dylan’s Grandma. Hendrix powered his Fuzz Face with Gypsies, sun, and rainbows…an a little plutonium Roger Mayer stole from the Royal Navy…
