Tearjerker enclosure
Just wanted to know if the Tearjerker Wah will fit in one of the BYOC Wah enclosures? They look very nice..
Those might be the same ones offered by Smallbear, but powdercoated.
If they're the same spec as a Crybaby (and the description seems to imply that they are) then they should work.
Did you end up using this enclosure? I'm about to start a TearJerker build and I'm looking for a good enclosure.
I had a panic moment and just wanted get some clarification. Did I order the wrong enclosure from smallbear? It says "expression shell". I ask because there is no square hole for the DC jack it it and thats what I also have.
This is what I have and the only wah-type enclosure I could find on the smallbear site.
Woops, thanks. Buy some primer and paint while you're at it ?
Fyi, there is no square hole for the DC jack on mine. I will check to see if a standard innie fits.
Unfortunately I haven’t had a chance yet! Will definitely give it a go eventually. I have such a massive backlog of completed projects to be boxed! Good luck, are you going with the small bear one or are you going to give the BYOC enclosure a try?
I think I’ll give the Smallbear one a try, since I know it will fit. Assuming the DC jack works with it. But I do like the look of the BYOC one better. Maybe I’ll get them both! I’ll post the completed one once I’ve had a chance to put it together.
Here's the Smallbear expression enclosure
As you can see, the PCB mount DC jack will align just right but it might look weird with that round hole. If you're cool with it, have at. The Lumberg innie jack in the photo won't fit in the hole, but would if you drilled it about one step further. You'd just need to run some wires to the PCB.
