fig
Village Idiot
This is on the way to me, and a few spare chips. I'm thinking mind-blowing compression
Hmm, a ducky dynamic ducker you say? I'll twy to cwack that out.Ooh nice I don't know what it is but
Make a dynamic ducker sounds cool
Ducking - Wikipedia
en.wikipedia.org
The THAT4305 dev board and info packet arrived today from Mouser....in case anyone has an interest in what you get...Interesting
What Is Sidechain and How To Use It? Abbey Road Recordist Matt Jones Explains
Do you ever find your mix sounds great on one section of your track, but overcrowded or muddy on another part once more textures come in? If so, you may want to try using sidechaining. Abbey Road Recordist Matt Jones explains what sidechaining is, how to use it and his tips on how to achieve the...www.abbeyroad.com
Pumping (audio) - Wikipedia
en.wikipedia.org
Do a ducking pumpin side chain compressor.......
My wallets out already
Are those the FXcore that you ordered on the bubble back in the top left?Deeper fig, you must go deeeeeeeper ....
Yes sir. Ohhh so why did I post it here? Gotcha. No idea....Too many projects, not enough brain cells.Are those the FXcore that you ordered on the bubble back in the top left?
Solder paste is quite literally that simple to use. For stuff where there’s only SMD on one side of the board you can even use a toaster oven instead of a dedicated hot air station if you’re careful. That’s actually the only method in which I’ve used solder paste myself (hot air stations are expensive!) and it worked quite well— I used the same toaster that I use for curing paint and stabilizing resin. Just don’t use anything you actually put food inSomeone walk me off this ledge or go on and give me a shove...
THIS looks stupid-simple.....
My sole attempt at curing paint in my toaster oven did not yield the results I was hoping for. Got any pointers Nick?Solder paste is quite literally that simple to use. For stuff where there’s only SMD on one side of the board you can even use a toaster oven instead of a dedicated hot air station if you’re careful. That’s actually the only method in which I’ve used solder paste myself (hot air stations are expensive!) and it worked quite well— I used the same toaster that I use for curing paint and stabilizing resin. Just don’t use anything you actually put food in
My hot air station was only $60. There are expensive stations out there, but you don't need fancy to get the job done. When I do whole boards with stencil and paste I use my $200 reflow oven (also a bargain if you're doing a lot of SMD), but for two or three components on a board I'll use the hot air station.hot air stations are expensive!
THIN COATS OF PAINT.My sole attempt at curing paint in my toaster oven did not yield the results I was hoping for. Got any pointers Nick?
It was hammertone, which I found didn't hammer as well with thin coatsTHIN COATS OF PAINT.
I always did 15 minutes at 300 degrees, but I've seen people do lower temps for longer times as well.
Absolutely. The M8000s are rare...I have a couple of CS5368s I hope will play along nicely. CabinTech has some M9000s.My hot air station was only $60. There are expensive stations out there, but you don't need fancy to get the job done. When I do whole boards with stencil and paste I use my $200 reflow oven (also a bargain if you're doing a lot of SMD), but for two or three components on a board I'll use the hot air station.
With regards to FXCore I've been impressed with the sound quality and options compared to FV-1, but I haven't had a chance to actually do anything DIY with FXCore since the external ADC/DAC I was looking at got hit by the semiconductor shortage. I know Alexander uses it in one of his new pedals, and I saw one guy do a build with one on another forum, but that's all I've seen of FXCore in the wild.
Primer and paint I’ve had good results with 250° for 25 min. Still haven’t found good results of any kind with clear coats— baked or not.My sole attempt at curing paint in my toaster oven did not yield the results I was hoping for. Got any pointers Nick?
