TravisM
The X,Y coordinated were all measured and should be accurate. I added the extra 0.2mm for powder coating. I used the stated diameter for SW1 from the tayda datasheet, I used 3mm for the LED indicator, I used 7.9mm diameter for the power plug. Please double check the diameters against what you plan to use and adjust accordingly.
