Big Monk
All the tweaking and breadboarding.
All the frustration.
We want a single fuzz to deliver the classic tone of the Tonebender MK II, the Tonebender MK 1.5, and the Fuzz Face. At least I think we do. I do. I know that.
What do we need?
First, a main control set. Level, fuzz, pre-gain and a blend control seems reasonable.
Second, a secondary control set. These should be the 9 mm pots with the external shaft that acts like a mini knob and has the marker. My thought would be bias for Q1 and Q3, a mid/output knob and emitter resistance on Q2 and Q3.
Lastly, switching. My thoughts go immediately to 3 mini toggles for Si to Ge. Also, a MK II/Fuzz Face topology stomp for getting rid of Q1. Also, mini toggles for input, treble bleed, emitter and output caps.
Sounds insane, right?
It would allow you to switch between all these circuits or Frankenstein your own.
Also, I think a pickup simulator is a must.
Let’s discuss. I’ll design the board and all the build docs and share it completely with the forum.
I've decided to change the OP to reflect the change in course I've taken on this project. This is now essentially a super modified Skreddy Lunar Module. I've also researched and factored in a few things from the Screwdriver and Hybrid Fuzz Driver. I'm still rsearching and assembling a bunch of tweakable things on the breadboard. Stay tuned...
EDIT (11/29/2021) - Changed the title of the thread so I can document the breadboarding without starting a new thread.
This is going onto the Protoboard this week after I get my Aion Ares redo finished.
The base circuit will have a similar topology to the Skreddy LM/SD/HFD but will be more of a Silicon Tonebender MK II in spirit while retaining some of the circuit tweaks of the Skreddy pedals.
I’ll be documenting the building and sound testing of the base circuit and also after I add some of the other circuit mods.
