Hexjibber
Hi all,
Just had an idea come to mind for my upcoming Thermionic Deluxe build and wondered if anyone could tell me if it's possible and how I might approach it if so?
Ideally I would like to be able to add a TRS switching jack that can enable changing between channel A & B on the pedal via a remote in the same fashion that a lot of amp channel switchers work. The only problem is having never worked on an amp I have no idea how it is done? My guess (and from a bit of Googling) is that it's via some kind of relay but I haven't come across this before in a pedal build, and for obvious reasons as there is normally a switch on the pedal itself to do this job!
For a bit of background, I would ideally like to incorporate this pedal into a Line 6 HX Effects rig which has TRS outputs available to switch channels on a standard amp. If not being used in that set up I would like to still be able to use it normally as well in my more regular pedal board set up.
Is this at all possible, or not worth pursuing?
Thanks!
Graham
Thanks!
Graham
