thesoundofjusticefx
Hello everyone. They both seem to need the blend/mix control to be set very high. D3lay around noon but the Threeverb around 3 o'clock. The delay output volume is still useable with the blend control around noon to get the delay loud enough to enjoy. However the Threeverb level is far below unity when the mix control is set to almost max. This setting gets the reverb level high enough to hear but is far too quiet overall output level. When setting the mix to zero, the volume control seems to be working fine boosting about 6db like the specs say it should. I am in the process of checking all my values again. The crystal is correct and the spin fv-1 came pre soldered. I posted the pics so hopefully someone might see something I'm not. Hopefully someone has experience this and knows what the problem could be. Thanks everyone.
