Tic-tac-toe Game Based on Arduino and HMI
rowan
Materials required for the experiment
Arduino UNO
Stone STWI070WT-01 TFT LCD display
The system principle
Specify the first tap on the screen must be O, the second tap on the screen is X, has been doing this cycle. Set 8 arrays to store the number of O and X in each row, column and diagonal of each grid, as long as there are three of the same mark is the victory, then there will be a flashing red box to prove the victory of the row, column or diagonal, and then tap reset to start the game again.
Simple connection diagram
GUI design
Reactions: fig
rowan
part of code sharing
Code:
unsigned int r_flag1 = 0;
uint8_t   RecievedTemp1[30]       = {0};
//uint8_t   *RecievedTemp1 = new uint8_t[30];
uint8_t   cout_i = 0;
unsigned int quan_hang1 = 0;
unsigned int quan_hang2 = 0;
unsigned int quan_hang3 = 0;
unsigned int quan_lie1 = 0;
unsigned int quan_lie2 = 0;
unsigned int quan_lie3 = 0;
unsigned int quan_zuoxia = 0;
unsigned int quan_youxia = 0;
//unsigned int quan[8]={0};
unsigned int cha_hang1 = 0;
unsigned int cha_hang2 = 0;
unsigned int cha_hang3 = 0;
unsigned int cha_lie1 = 0;
unsigned int cha_lie2 = 0;
unsigned int cha_lie3 = 0;
unsigned int cha_zuoxia = 0;
unsigned int cha_youxia = 0;
unsigned int cha[8]={0};
void setup()
   Serial.begin(115200);
   for(int i=3; i<=8; i++)
   pinMode(i,OUTPUT);
void loop(){
  if(Serial.available() != 0)
//    for(cout_i = 0; cout_i < 30; cout_i ++)
//        //RecievedTemp1[cout_i] = Serial.readBytes(RecievedTemp1, 15);
//        Serial.readBytes(RecievedTemp1, 20);
//        //Serial.println(RecievedTemp1[cout_i]);
    for(cout_i = 0; cout_i < 19; cout_i ++)
    switch(RecievedTemp1[13])
  case 49:
        if((r_flag1 == 0)&&(RecievedTemp1[14]==2))
        Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image2\",\"image\":\"circle\"}>ET"));
        r_flag1 = 1;
        quan_hang1++;
        quan_lie1++;
        quan_youxia++;
//        quan[0]++;
//        quan[3]++;
//        quan[7]++;
        Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button1\",\"enable\":false}>ET"));
        else if((r_flag1 == 1)&&(RecievedTemp1[14]==2))
          Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image2\",\"image\":\"x\"}>ET"));
         r_flag1 = 0;
            cha_hang1++;
            cha_lie1++;
            cha_youxia++;
//        cha[0]++;
//        cha[3]++;
//        cha[7]++;
        break;
  case 50:
        Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image3\",\"image\":\"circle\"}>ET"));
        r_flag1 = 1;
        quan_hang1++;
            quan_lie2++;
//        quan[0]++;
//        quan[4]++;
            Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button2\",\"enable\":false}>ET"));
          Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image3\",\"image\":\"x\"}>ET"));
         r_flag1 = 0;
         cha_hang1++;
           cha_lie2++;
//        cha[0]++;
//        cha[4]++;
        break;
  case 51:
        Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image4\",\"image\":\"circle\"}>ET"));
        r_flag1 = 1;
        quan_hang1++;
            quan_lie3++;
            quan_zuoxia++;
//        quan[0]++;
//        quan[5]++;
//        quan[6]++;
            Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button3\",\"enable\":false}>ET"));
          Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image4\",\"image\":\"x\"}>ET"));
         r_flag1 = 0;
         cha_hang1++;
           cha_lie3++;
            cha_zuoxia++;
//        cha[0]++;
//        cha[5]++;
//        cha[6]++;
        break;
  case 52:
        Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image5\",\"image\":\"circle\"}>ET"));
        r_flag1 = 1;
        quan_hang2++;
            quan_lie1++;
            Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button4\",\"enable\":false}>ET"));
          Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image5\",\"image\":\"x\"}>ET"));
         r_flag1 = 0;
         cha_hang2++;
           cha_lie1++;
        break;
  case 53:
        Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image6\",\"image\":\"circle\"}>ET"));
        r_flag1 = 1;
        quan_hang2++;
            quan_lie2++;
            quan_zuoxia++;
            quan_youxia++;
            Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button5\",\"enable\":false}>ET"));
          Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image6\",\"image\":\"x\"}>ET"));
          r_flag1 = 0;
          cha_hang2++;
            cha_lie2++;
            cha_zuoxia++;
            cha_youxia++;
        break;
  case 54:
        Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image7\",\"image\":\"circle\"}>ET"));
        r_flag1 = 1;
        quan_hang2++;
            quan_lie3++;
//        quan[1]++;
            Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button6\",\"enable\":false}>ET"));
          Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image7\",\"image\":\"x\"}>ET"));
         r_flag1 = 0;
         cha_hang2++;
           cha_lie3++;
        break;
  case 55:
        Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image8\",\"image\":\"circle\"}>ET"));
        r_flag1 = 1;
        quan_hang3++;
            quan_lie1++;
            quan_zuoxia++;
            Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button7\",\"enable\":false}>ET"));
          Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image8\",\"image\":\"x\"}>ET"));
         r_flag1 = 0;
         cha_hang3++;
           cha_lie1++;
            cha_zuoxia++;
        break;
  case 56:
        Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image9\",\"image\":\"circle\"}>ET"));
        r_flag1 = 1;
        quan_hang3++;
            quan_lie2++;
            Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button8\",\"enable\":false}>ET"));
          Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image9\",\"image\":\"x\"}>ET"));
         r_flag1 = 0;
         cha_hang3++;
           cha_lie2++;
        break;
  case 57:
        Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image10\",\"image\":\"circle\"}>ET"));
        r_flag1 = 1;
        quan_hang3++;
            quan_lie3++;
            quan_youxia++;
            Serial.println(F("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button9\",\"enable\":false}>ET"));
          Serial.println(F("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image10\",\"image\":\"x\"}>ET"));
         r_flag1 = 0;
         cha_hang3++;
           cha_lie3++;
            cha_youxia++;
        break;
  case 48:
            r_flag1 = 0;
            quan_hang1=quan_hang2=quan_hang3=cha_hang1=cha_hang2=cha_hang3=0;
            quan_lie1=quan_lie2=quan_lie3=cha_lie1=cha_lie2=cha_lie3=0;
            quan_zuoxia=quan_youxia=cha_zuoxia=cha_youxia=0;
//            for(char count_i=50;count_i<58;count_i++)
//              Serial.println((("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image%c\",\"image\":\"bai\"}>ET"),count_i));
Reactions: fig
