Does it matter which way it is put in? The case gives no real indication.
Coda Well-known member Jun 8, 2021 #1 Does it matter which way it is put in? The case gives no real indication. Attachments C58903A9-B3A0-4F59-9D15-7A4893151214.jpeg 100 KB · Views: 16 053EF16C-50FF-44D9-8300-BB2BDE886BD6.jpeg 118.2 KB · Views: 15
Coda Well-known member Jun 8, 2021 #4 Pin 1 lines up with the square pad then, correct? Attachments 51B96291-5C5C-40DE-AEA0-A298A53427D7.jpeg 97.7 KB · Views: 8
Chuck D. Bones Circuit Wizard Jun 8, 2021 #5 Yes. Hopefully, you're asking this question before applying power.
Chuck D. Bones Circuit Wizard Jun 8, 2021 #6 BTW, this dot does not indicate IC alignment, it is a via under the IC. Would be better if such things did not appear on the assembly diagram.
Coda Well-known member Jun 8, 2021 #7 Chuck D. Bones said: Yes. Hopefully, you're asking this question before applying power. Click to expand... No power yet. I placed them with the corner dots closest to the square pads. Thanks to everyone for the help.
