BurntFingers
Weekend leftover parts project complete. The enclosure is from 2011 and one of Tayda's older style ones that are shorter and narrower than what they currently stock so I dicked up the drilling and left a vent at the top. Handy actually as there's too much toan in here anyway.
It's sort of an Electra distortion but built with whatever was in the drawer so not exactly to spec. Has a BC549 in there, a big muff tone control, I think a 220R coming off the emitter (as oppose 330R). I used the layout for the Woodrow from Tagboard effects.
It's a fun pedal. Definitely low gain (probably because of the pot value for the gain, I didn't have a 1k so had to use a 5k) and unity volume is about 80% of the dial.
I'm using it as a boost on a slightly dirty channel, or as a bit of grit on the clean channel. It definitely suits laid back, chilled bluesy crap with some warm reverb in the background. It's actually quite nice to not have a pedal where unity is 3/10 of the volume pot because it generally means you don't get the most out of it unless you can crank both the drive and the gain (looking at you, Hot Cake) which messes up any balance with the clean channel.
Fun stuff. Got a 1w resistor coming off the LED for maximum mojo tone.
Excuse the rat's nest wiring. Vero is a whole lot of fun.
