SOLVED Tone Pot Acting Like Volume Pot
joelorigo
I finished this Candid Drive and tested it on the Auditorium Test Platform and then in the enclosure. Everything seemed fine. I then took it apart, applied a waterslide decal and clear coat to the enclosure, and put it back together. Now the TONE pot is acting like a volume and I am almost certain it was previously acting like a proper tone pot before. Everything else seems normal.
Anything look like the obvious cause of that?
Looks like you soldered your power wires in after it was in the box, give em a scrub with a toothbrush and iso especially around the - pad and lug 1 of the tone control. Lug 1 isn’t connected in the schematic but if it is making a ground connection that would explain it.
All soldering was done before removal to work on enclosure graphics.
Looks like the power lead is almost long enough to make contact with #3 pad of the tone control (to the left of Music6000's blue circle).
You COULD make a connection between blue and red (lugs 1&2), the circuit will still behave as it should and even if ever the pot craps out, in most cases the signal would still get through.
