jeffwhitfield
I built this one a few weeks ago. By far one of the most original distortion boxes I've tried yet. At first, I wasn't sure if it was working right. The problem was that setting the gain up high causes it to clip with a gated effect. It's actually a pretty cool effect...but unexpected from a distortion pedal. The reason is due to how the transformer works. Push it hard enough and it clips really hard.
In terms of sound, it adds quite a bit of grit. By itself, it's a pretty good distortion box...but where it shines is when you stack something behind it. In this case, I stacked it with a Harmonic Perculator clone. Once I did that, holy cow, did it ever open up! Seems that pushing it with a Germanium-based boost or pre-amp really makes this one sing. And you don't have to turn up the gain much to get it there. For me, the sweet spot was around 10-11 o'clock...not quite halfway.
For the design, I used a flat black textured enclosure. Used AmplifyFun for the UV printing. Wanted something that sort of resembled the original IVP pre-amp that this particular circuit was based on. I found a really cool topographical graphic and added it to the bottom. It's funny cause it sort of has that Asteroids thing going with it. Still a damn cool effect for the pedal though. Pleased with how it turned out.
