Troubleshooting Glory Hole
schnerf
It's all together, but it's my first build (of relatively few) that hasn't worked right out of the gates.
I had dry signal when bypassed.
No sound when engaged
No LED
I switched the LED leads, so the red wire goes to A and black to K, even though I had it red to square pad and black to circle pad like I've done previously (this time, I used the pre-wired LED from lovemyswitches--I guess they used opposite wire coloring?) (The diodes are added based on the stripes, the FET/saddle are aligned with the notch toward the top, and all of the electrolytic capacitors are positive side on top (in the square pad) and stripe on the bottom -- my one worry is if the LED was reverse what I'm used to, are the electrolytics reversed as well?)
I still have dry signal on bypass
LED works!
When LED is on, all I get is a hum.
I looked for solder bridges and ran a blade between everything.
I checked for ground faults (everything that beeped looks like it should have a ground connection, except I'm not positive the right-most pin on the A100K pot. This was the only pot pin to beep. The mini toggle didn't beep anywhere.) On the 3PDT breakout, GND always beeped, IN beeped when the LED is lit, and OUT beeped when the LED wasn't lit.
I'm not getting any ground continuity beep on the surface mount transistor leads to the breakout or pads (main board or breakout). I soldered it to the 5457 side of the board and connected left pad to left pad (D), middle to middle (s) and right to right (G) with the chip side up.
I checked wiring (seems good).
I'll order an audio probe, but any ideas on what else I can test?
Also, I got this from Lovemyswitches:
You'll want to test with your multimeter that the black on the LED is connected to ground cuz with out the resistor in there there will be no connection to ground so you need to figure out where that resistor connected to ground and then black will go there
Now I have it in the A/K LED spot. (Now with red going to A and black going to K (and it is beeping as connected to ground). I jumped the R102 resistor spot with a clipped resistor lead and didn't install this resistor. Should I rewire the LED so that the black wire goes somewhere else altogether? Would that affect this?
Best to post some pictures of both sides of the board so we can clearly see it and trace your offboard wiring
Check your DC jack wiring if your using one make sure you've got nice correct connections obviously I can't see it but that's what I'd check with it humming in effects mode
Your LED just indicates what position your 3PDTs in you'd get bypass without power or even if you put your IN cable to your OUT jack and visa versa
From your description it sounds like a power problem but as I say it's just guessing without being able to see it
I'm sure with pics somebody will hopefully see something and help you get it going
Hey guys, sorry for the delay. My computer died and one thing or another kept me away.
I've attached photos. Some notes:
I bent the prongs on the DC jack to fit in the pedal. I have newer, smaller jacks I can use now, but need washers since they are now smaller than the hole in the case. I don't think that's the problem however.
Bypassed seems fine. When engaged, the LED lights up and sound cuts out. If I turn up the amp volume I can hear a FAINT overdriven tone with all pots maxed.
Sorry for the messy flux. I tried cleaning it with alcohol but it just made it look worse.
Nope. All tests since the initial assembly have been outside of the enclosure (except for the DC jack since it goes through it). I also made sure there was nothing else touching the enclosure to avoid grounding/shorts.
What voltage do you get to the pcb + and - pads we know you're getting something because your LED lights up but what's the exact reading
Ok so I’m very basic with the multimeter so I’m going to explain how I did it in case I’m a moron.
I plugged the dc jack into the old 9v 1700 1spot. The pedal was “on” (the led was on). I set the multimeter to V, put the black common on the - PCB pad and the red on the + PCB pad. It read 9.48 V DC.
As far as I can see all your values are correct I'd be looking for a dry solder joint visually inspect your joints and reflow any dull looking or ball like joints
Post a close up of your FET so we can see how it's soldered to the adaptor board
I just finished up my glory hole too and I am having the exact same issue. Power reading is good, no dry solder joints, wiring is exactly how the schematic specifies, but still nothing. At first my led wasn’t turning on like you, but it turned out to be that it was making contact with my case. I’m still not getting any signal when the pedal is on. Any help is appreciated
From what I can tell, nothing is bridging and causing a bad connection. All the wires and joints are making full contact, and nothing is in the wrong place. Now I could be wrong because I’m fairly new at this and a second set of eyes always helps. Something that might be worth noting, is that I did not have a 2N5457 transistor on hand, so I substituted it with a 2N3904 leftover from another pedal. But from what I read that shouldn’t keep the pedal from working? Again I could be wrong. Just to explain the problem again, the pedal works fine in bypass, signal flows through, but as soon as I switch it on, it cuts out and nothing comes through anymore.
I believe we have identified the problem. A BJT (bipolar junction transistor) is almost never a drop-in replacement for a JFET. Certainly not gonna work in this pedal.
Three questions:
Do you have plans to acquire a 2N5457?
Do you have any JFETs?
Are there any other parts substitutions you want to tell us about?
Three questions:
THANK YOU!! Right after posting here, I posted on the DIYPedals subreddit and got the same response. I had no idea what JFET was until yesterday. But now I do and ordered a pack off eBay that should be here later this week. This was the only substitution so we’ll see what happens after I replace it. Thanks for the help! Also, sorry for hijacking this thread OP! Maybe you’re having the same issue?
Oh no, buying JFETs off eBay is not a good idea. Tons and tons of fake/out of spec ones out there, hopefully you’ll get some decent ones but if not you must get them from somewhere reputable like smallbear electronics. What kind did you order?
I agree with what Nostrodoomus said.
I get the feeling that you're not just new to this site, you're new to pedal building. Here's a warning that may have come too late for you:
Buying transistors, particularly JFETs, on eBay is very risky. Most of the sellers do not know any more than you do about JFETs. And then there are the guys who knowingly sell crap. I'd say the chances that you get anything good are no better than 50/50. You need to have the tools and skills to test transistors and the heart of a gambler if you want to buy semiconductors on eBay. Unless you have a socket on the board, and it looks like you don't, then don't waste your time installing questionable parts. Or the next question you'll be asking us is "how do I repair a damaged trace?"
Welp, wish I had come back and read your responses first. Your assessment of me not knowing what I'm doing was correct. I ordered some JFET 2N5457's on eBay and just threw them in the pedal and still nothing. Either they are fake or something else is really wrong with my pedal. Is there any way I can test to see if they're legit without buying a socket? Also do you guys know anywhere I can get legit 5457's? Tayda doesn't have any, smallbear doesn't either. eBay had an abundance but I guess I know better now. This is becoming really aggravating. I also ordered some J201 transistors from the same guy on eBay and I'm having second thoughts about putting those anywhere near my other pedals
