comradehoser
On a first fire-up building streak, and making this one for my brother in law, the streak abruptly ended
Built everything to spec as far as i know except the 20uf caps (used 22uf). Have a barely audible signal. The issue i think is the DC is blocked. Only have fractional voltages after the 5817 (including to pins 1 and 8 of the charge pump, the resistors after D1, and all transistor legs) which i noticed immediately while going to trim the transistor bias before fire up.
Reflowed all points, rechecked wiring, continuity (including socket to board), components and cap orientations. Subbed the 1044scpa, tried different transistors, same deal.
At this point, I'm kind of stumped as nothing is coming up for me in the components or soldering. Bad trace after the schottky is all i can think of.
But maybe you all can see something i can't.
Gutshots
Gutshots
