Ungula aka Hoof with MP38
How does it sound? The stock Hoof (Ungula) runs the bias pretty hot on the two germaniums. Leaky transistors may saturate even with no signal. Do us a favor and measure the collector voltages on Q2 & Q3.
That looks good, both transistors have enough headroom. If you want to try something different, remove D2 or both D1 & D2. It will get louder, not that you need any more volume, but it will also reduce the compression and make the clipping asymmetrical, for more even harmonics. For less midrange scoop, increase C10 to 15nF or 22nF. The SHIFT control will still have plenty of range. Finally, if it's too hissy at high FUZZ settings, try replacing Q1 with a low-noise transistor like BC109C, MPSA18, 2N5088/89 or 2N5210.
